[XTR] Reputation System - İtibar Puanı Sistemi
Premium[XTR] Reputation System - İtibar Puanı Sistemi 1.0.4
Shit, I guess I mess up the addon. I get now:
Any chance to fix that issue ?
I have this modification installed on an XF 2.3.9 site with a custom skin and nothing is showing up on the forum. It all works in the admin area. I see no cron jobs to run. Nothing is in the postbit area, even if I use the default skin.
Any ideas what I should look into to get it to show up? It's enabled yet nothing shows up at all.
Template modifications may not always apply correctly on custom themes. Have you had a chance to test it on the default style? Does it work properly there?
E
elchorizo Replying to XenTR
Yes, I tried the default skin and nothing shows up there either. Are there supposed to be any cron jobs associated with this? I didn't see any. What type of debug or testing can I do, or SQL...
Yes, I tried the default skin and nothing shows up there either. Are there supposed to be any cron jobs associated with this? I didn't see any. What type of debug or testing can I do, or SQL queries to run to help debug it.
It's definitely not the skins since it isn't showing up on the stock skin either :(
I've figured it out. The usergroup permissions were not set. I guess I just completely didn't see that part in the instructions. My apologies!
  1. Reputation
  2. Reputation System
  3. [XTR] Reputation System
  4. ranks
  5. rank
  6. xenforo rank
  7. Kaynak
  8. reputation-ranks
  9. progress
  10. language
