Add-Ons [XTR] Enforce Post Rules
Ovunc Dinc kullanıcımız yeni bir ürün yayınladı: [XTR] Enforce Post Rules 1.0.0 - This add-on allows you to apply rules of creating a new thread within specific nodes on your forum.
Ürün Açıklaması
After installing and configuring, (enter the post terms and rules per node) members will be prompted to check a box stating they have read the node post rules with a link to those rules. If a user does not accept to the rules they will be unable to create the thread.
These options are intended to be directly manage the enforce post rules.
enforcepostrules_options-png.3231
You can enter and manage the post terms and rules per nodes.
Like as below;
enforcepostrules_node-png.3232
Now, it's time to check to result,
As you see the below, Main forum has a post terms and rules!
enforcepostrules_post_thread-1-png.3233
Member can display the terms and rules via two section,
1. Overlay
2. Post terms and rule info block (scrolling is supported)
enforcepostrules_post_thread-2-png.3234
If the specified content/entered rule (Post Terms and Rules) is higher than scroll height, scrolling option will be active.
enforcepostrules_post_thread-scroll-png.3235
Also you can manage the scroll height (to when it will be active) via add-on options.
enforcepostrules_options_scroll-png.3236
When members accept the rules Post Thread button will be enable.
enforcepostrules_post_thread-3-png.3237
Quick post thread option has supported with same conditions and design.
Before read and accept to rules,
enforcepostrules_qucik_post_thread-png.3238
So, can we exclude these rules for specific user groups?
You can do it via permissions.
enforcepostrules_perm-png.3239
Now, It's time to set the rules for other nodes ... (y)
Genişletilmiş Ürün Bilgisi
  • You can enter and manage the post terms and rules per nodes.
  • Exclude these rules for specific user groups.
  • Post terms and rule info block (scrolling is supported)
Bu ürün hakkında daha fazla bilgi edinin ...
