- Telefon No
- 055********
[XTR] Display Group For Signatures için @XDinc kullanıcısı yeni bir güncelleme yayınladı.
[XTR] Display Group For Signatures 1.0.3
XenForo 2.2.x Compatibility Update
Note: Please do not install the add-on, if you are using lower than XF 2.2.2+.
This version only support to XenForo 2.2.2+.
1.0.3 Change log
What's new?
- Confirm XF 2.2+ support
- Add-on templates updated.
- Requires php 7.2+
- Supports only XF 2.2.2+
- In this release some of modifications / optimizations has been applied for XF 2.2.+
1.0.3 Change log
What's new?
- New phrases have been added.
- Build custom signature macro has been changed.
- Node type support has been applied for XF 2.2.+
- TH Styles compatibility issues have been fixed.
