Add-Ons Thread Title Control System
A new product by XDinc is available: Thread Title Control System 1.0.0 - This add-on allows you implement recommended title controls for SEO.
Description
4_best_practices_effective_titles-png.5391
Watch your title length​
If your title is too long, search engines may cut it off by adding an ellipsis ("...") and could end up omitting important words. While we generally recommend keeping your titles under 60 characters long, the exact limit is a bit more complicated and is based on a 600-pixel container.
Some characters naturally take up more space. A character like uppercase "W" is wider than a lowercase character like "i" or "t".
Try to avoid ALL CAPS titles. They may be hard for search visitors to read, and may severely limit the number of characters Google will display.
Keep in mind that, even within a reasonable length limit, search engines may choose to display a different title than what you provide in your title tag.
ACP Gen. Options
titlecontrol_acp-png.5392
Title change case
◾ To exclude capital letters from your title, select
◾ To capitalize all of the letters, select
◾ To capitalize the first letter of a title and leave all other letters as lowercase, select
◾ To capitalize the first letter of each word and leave the other letters lowercase, select
titlecontrol_acp_limit-png.5394
Choose 4-8 words and/or keyphrases that best suit your thread title. To add a keyphrase i.e. character counter simply add a hyphen between the words so it becomes character-counter. This will then be correctly formatted on output. Note: Google places zero emphasis on keywords at this time, but it can't hurt to include them.
titlecontrol_acp_disallow-png.5395
titlecontrol_acp_exclude-png.5396
titlecontrol_disallow_word-char-png.5397
titlecontrol_word_count-png.5398
titlecontrol_disallow_word-char-png.5399
Extended Product Information
  • Thread title change case
  • Min. thread title word count
  • Max. thread title word count
  • Min. thread title length
  • Max. thread title length
  • You may disallow characters
  • You may disallow words
  • Select nodes where the title control limits can be bypass.
  • Select user groups, which group(s) can bypass the title limits control.
