StylesRyzer Pro
Welcome! Please Login or Register to view hidden content.
Hello Paras ,
To be clear, this is not a style issue.
Ads are usually requested asynchronously and dynamically add content to your page during or after page load.
Remove auto ads from your site or, you could disable problematic Auto ads formats (I guess "In-page ads" is one of them) and then implement ad units code (in addition to the existing Auto ads code you already have implemented)
Regards.
Ryzer Pro için XenTR kullanıcısı yeni bir güncelleme yayınladı.
Ryzer Pro 2.2.9
This update simply fixes a few minor bugs and addresses the outdated template that is appearing on the latest version of XenForo (2.2.9).
Before Upgrading:
  • XenForo 2.2.9 compatibility
  • Fixed a bug with horizontal layout from message layouts
  • PHP 8 Template error: [E_WARNING] A non-numeric value encountered bug fixed
A new update is available for Ryzer Pro by XenTR.
Ryzer Pro 2.2.11
Today, we are releasing a major update to Ryzer Pro since it!
With so many new features, changes and fixes there is something for everyone. Without further ado, We will discuss some of the big features and changes made in this release.
As you know, the Ryzer Pro design has both Light and Dark versions.
We also decided to create a Black version. We are sure you will love the changes in this version.
The biggest feature is that all functions of the theme are provided to work more stable. In addition to all these, many new style features have been included and necessary arrangements have been made to make these features look more visually elegant.
Also, a child style called Ryzer Black is included in the Ryzer Pro version.
The background color change structure has been completely renewed and now works smoothly in all styles.
For more information visit the link below
Before Upgrading:
Please do not forget a back up your current styles before importing the new version. Backing up is simply exporting your current styles before upgrading.
  • XenForo 2.2.11 compatibility
  • The add-on of the Ryzer Pro design has been updated.
  • All modified templates have been rearranged.
  • The quick Touch section updated
  • The old color picker design was designed like the Revolution structure.
  • Color choices are made available for all themes.
  • Node forums have been rearranged.
  • Fixed the scrolling issue on the sidebar page refreshes.
  • The Search field has been changed to make it manageable by adding a group called Search to the style properties.
  • The background Chooser structure has been completely changed.
  • Fixed Google font contains invalid characters error.
  • Corrections were made in the Statistics Section.
  • Improvements were made to the Visitor card and reaction areas on the main page.
  • Some language expressions were removed and new ones were added.
  • Changes were made in many other sections.
Ryzer Pro 2.2.12
This update fixes a few minor bugs, also addresses the outdated template that is appearing on the latest version of XenForo v2.2.12
Before Upgrading:
  • XenForo 2.2.12 compatibility
Which answer button are you talking about?
An arrangement will be made regarding this.
Copyright information is not included in the themes own templates. In the master structure, copyright information is included in the add-on.
For example, you buy a plugin and the copyright information of this plugin is visible in all themes. For this, it is necessary to buy with copyright at the time of purchase.
I didn't disable the default theme. All members can choose that theme. So why should your copyrght footer appear there?
I just realized this.
XenForo development commands are done through the templates of the Master theme. Therefore, template modification operations are included in the templates of the master theme. All operations done here are automatically applied to all other themes.
Please help.
For no.1, I want my members to go straight to the question type threadinstead of discussion thread. I mean, they landing on the question tab.
For no. 2, I want visitors to see all of the question-specific lists.
