StylesRyzer Pro
A new update is available for Ryzer Pro by XenTR.
Ryzer Pro 2.2.8
This brings our styles up-to date with XenForo 2.2.8.
Please follow the update change log. You may download the update with a valid license.
Before Upgrading
XenForo 2.2.8 Compatibility Update
  • All outdated templates are updated to 2.2.8 and also confirmed XF v2.2.8 compatibility.
  • Template modifications are updated.
When uploading multiple images while posting in the section, clicking the Insert multiple, Select all button after the upload is complete is not valid.
Style Version: 2.2.8
Please check the issue, thanks.
HenJi ;
感谢您的反馈意见。 这些问题通常是由带有 .json 文件的插件引起的。
您可以尝试禁用您正在使用的插件吗?
Such problems are usually caused by javascript. Could you please check by disabling the add-ons you are using?
We will check whether the problem is caused by the theme and offer a solution.
Regards.
Welcome! Please Login or Register to view hidden content.
I tried to disable all plugins except the ones that come with the theme.
The problem still exists, waiting for the result of your check.
Thank you for your reply.
Hi HenJi we have detected the problem.
It comes from the button effect!
Could you please disable the button effect following style properties,
Also, we will release a new version as soon as possible!
Thank you for your feedback.
Hi Paras
Yes, we've checked it! We are working for new release.
To be clear, it's a loophole caused by the node icons, many actions are on our to do list that will improve the situation in the responsive (mobile) view.
We care about all feedback from our customers.(y)
Ryzer Pro için XenTR kullanıcısı yeni bir güncelleme yayınladı.
Ryzer Pro 2.2.8.1
This brings our styles up-to-date with XenForo v2.2.8 Patch 1
Info:
With this update, the style modifier feature is built into the style properties. There is no longer any need to install the add-on in this link.
Customers who have previously purchased this design should first uninstall the add-on mentioned above. Instead, they can use this feature included in the theme.
You can find this property in the style properties. ↓├ XenTR ┤ Style changer
Before Upgrading
  • All templates have been updated for XenForo v2.2.8 Patch 1.
  • Fixed the issue where the multi-add button was not active while sending a message.
  • Fixed indentation issue in forum titles on mobile devices.
  • It is no longer necessary to install the style changer add-on externally. The style changer is included in the theme's own features.
Hello,
Sorry if this is in the wrong forum, but I noticed the green user online indicator animation (on the postbit) isn't smooth. It flashes solid then gradually fades in and out. I thought it should be a smooth fade in and out. This is on Ryzer Pro 2.2.8.
The notification indicator (activated when someone reports a post for example) does fade in and out smoothly.
Thank you for any help, love the theme!
