Copyright Light Pearl 2.2.15
A new update is available for Light Pearl by XenTR.
Light Pearl 2.2.6.0.0
Please do not install the style, if you are using lower than XF 2.2.x
Note: We strongly recommend installing the 2.2.5 Versions from the archive.
You can see the changes made regarding the designs from the link below.
Light Pearl için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Light Pearl 2.2.7 Patch 1
Note: We strongly recommend installing the 2.2.7 Patch 1 Versions from the archive.
Updates after version 2.2.6.0.0 come with PHP 8 support.
  • Upgraded to xenForo 2.2.7 Patch 1
  • All templates are now compatible with XenForo's v2.2.7 Patch 1 Release.
Light Pearl 2.2.8
This brings our styles up-to date with XenForo 2.2.8.
Please follow the update change log. You may download the update with a valid license.
Before Upgrading
XenForo 2.2.8 Compatibility Update
  • All outdated templates are updated to 2.2.8 and also confirmed XF v2.2.8 compatibility.
  • Template modifications are updated.
Light Pearl 2.2.9
This update simply fixes a few minor bugs and addresses the outdated template that is appearing on the latest version of XenForo (2.2.9).
Before Upgrading:
  • XenForo 2.2.9 compatibility
Light Pearl 2.2.11
Release notes
This update simply fixes a few minor bugs and addresses the outdated template that is appearing on the latest version of XenForo 2.2.11.
Before Upgrading:
  • XenForo 2.2.11 compatibility
Light Pearl 2.2.12
This update fixes a few minor bugs, also addresses the outdated template that is appearing on the latest version of XenForo v2.2.12
Before Upgrading:
  • XenForo 2.2.12 compatibility
Light Pearl 2.2.13
  • XenForo v2.2.13 compatibility.
  • All templates are now compatible with XenForo v2.2.13 Release.
Light Pearl 2.2.15
  • Upgraded to xenForo 2.2.15
