Copyright Light Pearl 2.2.15
MFA
Innovate Dark temasında bulunan telif hakkı kaldırma seçeneği Light Pearl temasında yok sanırım göremedim!
.htaccess ile mi kaldırcaz nasıl ayarladınız acaba?
Şablon değişikliklerinden mi kapatacağız yoksa?
İndirdiğiniz sürüm telif hakkı kullanımı kaldırmaya izin verilen paketse destek talebi üzerinden bir bilet gönderebilirsiniz. Gerekli bilgiler detaylı olarak verilecektir.
Some improvements have been made with this release. Also updated according to XenForo 2.1.4 version.
  • Working with XF 2.1.4
  • Changed version to fit XF release number
  • A collapse feature has been added for sidebar elements from the style properties.
Upgraded to xenForo 2.1.5a
  • XenForo 2.1.5 ile çalışma (Working with XenForo 2.1.5)
  • Eski şablonlar yeni sürüm ile uyarlandı. (Old templates adapted with the new version.)
A new update is available for Light Pearl by XenTR.
Light Pearl 2.1.6
With the release of the XenForo 2.1.6 version, we are pleased to offer our valued customers a quick update to our themes.
This version has been updated on the theme frame and plugin. It has been specifically updated on the plugin that comes with the theme.
The updates are outlined below.
  • Theme plugin has been updated. Now for double-column forums, images can be uploaded directly. You don't need to enter a picture path for this.
  • Possible conflicts between plug-ins have been fixed.
  • Depending on the add-on update revisions were performed in numerous templates.
  • The add-on settings are now included in the style properties.
  • Numerous issues reported by customers have been fixed.
  • Some css edits have been made.
Light Pearl 2.1.7
Some improvements have been made with this release. Also updated according to XenForo 2.1.7 version.
With the release of the XenForo 2.1.7 version, we are pleased to offer our valued customers a quick update to our themes.
  • Working with XenForo 2.1.7
  • Old templates adapted with the new version.
Light Pearl için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Light Pearl 2.1.10 Patch 2
In this version, only old template updates have been made.
With the release of the XenForo 2.1.10 Patch 2 version, we are pleased to offer our valued customers a quick update to our themes.
  • Working with XenForo 2.1.10 Patch 2
  • The add-on that comes with the theme has been updated.
Light Pearl 2.2.0 Beta 1
With the release of the XenForo 2.2.0 Beta 1 version, we are pleased to offer our valued customers a quick update to our themes.
Note: This is beta software style. As you know, XenForo 2.2.0 Beta 1 version is not officially supported.
We do not recommend running beta software in a production environment, and support is limited at this time to questions here on the community forums.
You must test your add-ons thoroughly or look for updates.
What's changed with this release,
  • The add-on that came by design has been upgraded to version 1.0.5.
  • Old templates have been updated.
  • Node structures have been reorganized.
  • Node icon system has been updated.
  • If dual column image is selected from Node layout style options from the style properties, a button has been added to delete the images.
  • Arrangements have been made for a lot of new systems in style features.
  • According to XenForo forum structures, post_macros and message_macros templates were revised again.
  • Many other new arrangements and developments were realized.
With the release of the XenForo v2.2.0 Beta 1 version, we are pleased to offer our valued customers a quick update to our themes.
Note: [FONT=Segoe UI, Helvetica Neue, Helvetica, Roboto, Oxygen, Ubuntu, Cantarell, Fira Sans, Droid Sans, sans-serif]This release is beta release of XenForo. Support is limited for this version.[/FONT]
  • Working with XenForo v2.2.0 Beta 1
Light Pearl 2.2.0 Beta 2
With the release of the XenForo 2.2.0 Beta 2 version, we are pleased to offer our valued customers a quick update to our themes.
Note: This is beta software style. As you know, XenForo 2.2.0 Beta 2 version is not officially supported.
  • Some template updates that came with XenForo 2.2.0 Beta 2 have been made.
  • The share_controls.less file has been edited.
Light Pearl 2.2.0 Beta 2.1
Some bugs detected with this version were fixed and a small update was made.
  • The plugin for the design has been updated.
  • Some conflicts with other designs developed by XenTR have been fixed.
Light Pearl v2.2.0 RC2
This version is the update release for XenForo v2.2.0 Release Candidate 2.
  • All templates have been updated for XenForo v2.2.0 Release Candidate 2.
  • Some bugs detected were fixed and some minor changes were made.
Light Pearl 2.2.1
  • XenForo 2.2.1 compatibility
  • All templates are now compatible with XenForo's 2.2.1 Release.
  • Style now supports loading from archive.
  • The add-on developed for the theme has been updated.
Light Pearl 2.2.1.1
  • Message display issue for mobile devices has been resolved.
Light Pearl 2.2.2
  • XenForo 2.2.2 compatibility
  • All templates are now compatible with XenForo's 2.2.2 Release.
Light Pearl 2.2.3
  • XenForo v2.2.3 Patch 1 compatibility
  • All templates are now compatible with XenForo's v2.2.3 Patch 1 Release.
Light Pearl v2.2.3 Patch 1
  • The PAGE CONTAINER template has been edited for the user fields.
  • Some macro structures were used in order to ensure that the user areas are compatible with other extensions.
  • The xm_visitorTabs template has been removed.
  • Some .less templates have been updated.
Light Pearl 2.2.4
  • XenForo v2.2.4 compatibility
  • All templates are now compatible with XenForo's v2.2.4 Release.
