A new update is available for [XTR] Watermark Pro by Official.
Essential backward and forward stabilization has also been added to the XenForo core Flysystem iterations.
[XTR] Watermark Pro 1.0.6
This release contains critical system fixes designed specifically for administrators utilizing external cloud storage infrastructures (Abstract File Systems) such as Cloudflare R2 and AWS S3. Widespread issues like image watermark logos failing to load, custom font sizes being ignored, and statistic counters continually displaying zero have been comprehensively resolved.Essential backward and forward stabilization has also been added to the XenForo core Flysystem iterations.
- Fix: Addressed an asset path issue in remote file systems (S3/R2) installations that caused Image Watermark renders to be skipped and cancelled.
- Fix: Resolved a fallback scaling bug which prevented externally hosted fonts from being read, forcing the watermark text into XenForo's tiny default built-in font.
- Fix: Fixed the core directory scanner loop failure that was causing Cache, Backup, and Stats data to incorrectly return "0" on environments using cloud (Abstract) storage.
- Improvement: Made XenForo Flysystem directory loops fully compatible with paradigms to safeguard against future XenForo core structural updates.
- Cleanup: Removed obsolete and unused legacy code blocks to optimize the memory workload and maintain clean structure.
