Add-Ons [XTR] Resource Manager Layout 1.1.8
[XTR] Resource Pages için XenTR kullanıcısı yeni bir güncelleme yayınladı.
[XTR] Resource Manager Layout 1.1.3
Note: Please do not install the add-on, if you are using lower than XF 2.2.x
This version only support to XenForo 2.2.x +.
  • Added resource item extra URL option. (You may disable or enable extra URL field)
  • Added new template modifications.
  • Public templates updated.
  • Extra URL field bug is fixed while adding a new resource.
  • Style properties updated.
A new update is available for [XTR] Resource Manager Layout by XenTR.
[XTR] Resource Manager Layout 1.1.4
  • Confirmed XF 2.2.6 support
  • Stability and compatibility with the PHP 8+
  • Fixed reported error related that the "xtr_rm_extra_url field does not have a default value".
[XTR] Resource Manager Layout 1.1.5
  • [XFA] RM Marketplace compatibility
  • [XFA] Compatibility update with
    add-on.
A new update is available for [XTR] Resource Manager Layout by XDinc.
[XTR] Resource Manager Layout 1.1.6
XenForo 2.2.x and PHP 8.0+ Compatibility Update
  • Confirm XF 2.2.12+ Support
  • PHP 8.0 compatibility update.
1.1.6 Changelog
  • Compatibility update with
    add-on. (The price ribbon does not show for external purchases)
  • Add-on templates updated.
[XTR] Resource Manager Layout 1.1.7
1.1.7 Changelog
    addon.
  • Add-on template modifications updated.
Hello...
Great Addon!
However was wondering if you know a way I can keep the aspect ratio of my uploaded resource images while keeping the image contained so no matter the image I upload will 100% be visible with no cut off.
The issue is my images are not all the same size and I get some areas cut off and my OCD can't handle that!
ThankX!!!!
Also I forgot to ask, how do I get a more clear image on the resource overview page?
It is not near as sharp as it should be. and no I am not using smaller images.
ThanX!!!
Note: To have a better-looking resource list, it is recommended that you update the icons of existing products again according to the dimensions you have specified.
A new update is available for [XTR] Resource Manager Layout by Offical.
This update primarily brings compatibility with XenForo 2.3.x and includes important improvements to ensure better integration and stability with the [XFA] RM Marketplace add-on.
Support:
If you need assistance, feel free to contact us or create a support ticket.
We are always here to assist our customers and are happy to help resolve any issues you may encounter.
  • New templates were created and updated for XenForo 2.3.x compatibility.
  • All template modifications have been revised.
  • Macro structures have been updated and optimized.
  • Paid products now display correct ribbon data.
  • PHP file updated,
  • Button display issues have been fixed.
  • LESS templates were updated.
  • Sidebar issues on the resource detail page were resolved.
  • Compatibility issues with the [XFA] RM Marketplace add-on have been fixed for improved stability.
  1. resource pages
  2. Resource Manager Layout
  3. [XTR] Style Properties
  4. resource
  5. Resource Manager
