[XTR] FTSLider - Featured Thread Slider
Premium [XTR] FTSLider - Featured Thread Slider 1.1.7
Bu harika eklenti için teşekkürler, artık web sitemde onsuz olmak istemiyorum.
Eksik olan tek şey xenforo 2.3 sürümüne yapılan güncellemedir.
Ben ve birçok kişi bundan çok memnun oluruz... Bu eklenti için nereye bağışta bulunabilirim?
mfg
gundel tavası
Thanks for this great addon, I don't want to be without it on my website anymore.
The only thing missing is the update to xenforo version 2.3.
I and many others would be very happy about it...where can I donate for this addon?
mfg
gundel pan
OK, I got curious before just ditching the addon and found it seems simple enough to get it working again. Barely tested, YMMV, but for anyone interested, here you go.
For reference, XenForo ditched jQuery, and this addon's widget needs it, so we need to load in jQuery for it (short of rewriting this addon's javascript code to not use jQuery). And there are some changes the XF devs made to FontAwesome embeds that necessitate changes.
Edit the template "FTSlider_widget_block", find this:
Less:
Add this line after it:
Less:
Edit the template "FTSlider_js", replace both instances of:
Less:
with:
Less:
And replace both instances of:
Less:
with:
Less:
Edit the template "FTSlider_list_macros", and replace:
Less:
with:
Less:
It seems to be working now, though I've only partially tested it. Again, YMMV.
Merhaba
Değişiklikleri de kendim yaptım.
İşe yaradığını doğrulayabilirim, tabii ki XDinc in de buna bir göz atması gerekiyor!
Bunu böyle bırakabilir miyiz?
Harika, Brettfash'a çok teşekkürler.
Selamlama
gundel tavası
Hallo
Habe die Änderungen bei mir auch durchgeführt .
Kann bestätigen das es funktioniert , natürlich muss sich das auch XDinc auch mal anschauen !
Ob wir das auch so lassen dürfen !
Super , Vielen Dank an Brettfash.
Gruss
gundelpfanne
You may be wondering why this add-on has not been updated. Technology is evolving rapidly, and to ensure the best performance, security, and compatibility, it is always best to follow modern structures.
With the release of XenForo 2.3.x, we have determined that updating this add-on would not be particularly beneficial in the long run. Instead, improving the Featured Content feature integrated into XenForo ’s core structure will provide a much more effective solution.
Therefore, we have introduced an updated version through the new system for users familiar with our previous add-on. However, since this process requires significant effort and development, the latest version will be available as a paid product.
Thank you for your understanding!
To better illustrate this, here is an example image of the new system in action:
The product we developed as Enhanced Featured Carousel for XenForo 2.3.x is currently in the testing phase on our website. So far, no issues have been encountered during testing, but it will be available for sale in our store after further testing. ;)
Visit the link below to review.
Beklediğim bir çalışmaydı fakat resimlerin üzerinde tıklayınca bağlantıya gitmiyor. Alttaki açılır konu başlığına tıklayınca adrese gidiyor. Çünkü ziyaretçiler genelde resim üzerine tıklayarak içeriğe ulaşmaya çalışacaklar.
  1. xentr
  2. slider
  3. Featured Threads Slider
  4. Featured Thread Slider
  5. Featured threads
  6. featured
  7. ftslider
  8. featured thread
  9. thread slider
  10. [XTR] Featured Thread Slider 1.1.7
