Add-Ons [XTR] Enforce Post Rules 1.0.1
[XTR] Enforce Post Rules için @Ovunc Dinc kullanıcısı yeni bir güncelleme yayınladı.
XenForo 2.2.x Compatibility Update
  • Confirm XF 2.2+ support
Note: Please do not upgrade the add-on, if you are using lower than XF 2.2+.
This version only support to XF 2.2+.
1.0.1 Change log
  • Add-on templates updated to XF 2.2+
  • Forum rules macros has been updated per each node type (Discussion, Question, Article or Suggestion)
  • Post terms and rules option has been moved to below the Advanced options on ACP forum edit.
