Add-Ons [XTR] Custom Post Fields 1.0.9
Custom post fields allow you to define additional structured fields for users to fill in when replying a thread.
18.75 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements Sürümler (13) İncelemeler (1)
14 Ara 2024
A new update is available for [XTR] Custom Post Fields by XenTR Offical.
XenForo 2.3.x and PHP 8.3+ Compatibility Update
  • Confirm XF 2.3.x Support
  • PHP 8.3 compatibility update.
Support:
If you need assistance, feel free to contact us or create a support ticket.
We are always here to assist our customers and are happy to help resolve any issues you may encounter.
  • Add-on templates updated to XF 2.3.x
  • Template modifications are updated.
  • Macro structures have been updated.
Maybe some Option for different dates, only US avaible.
Example Default on Threadfield was : 01.03.2025
Posted : Mar 1, 2025
I've taken note of this issue and will investigate it thoroughly. If it's technically feasible and improves the user experience, I'll work on an update to include options for date formatting. If a suitable solution is found, we will release an update.
Have some Bug
[XTR] Custom Thread Fields Only
Only Content is show on hover thread, no added Fields are showing
Thread with no Content
On Hover Thread:
Thread with Content
On Hover Thread:
maybe option for Displaying added Fields would be great on hover thread
Thanx for Support
Regards
Hello,
The issues you've mentioned are related to different extensions, and we've examined each one in detail.
Regarding the [XTR] Custom Post Fields extension, the date display format you mentioned is not actually a bug, but rather it's using XenForo 's default date formatting. However, to improve your user experience, we've added a new setting called "Custom post fields list date format". With this setting, you can now customize the date display format to your preference (e.g., DD.MM.YYYY).
As for the [XTR] Custom Thread Fields Only extension, the "null" display you reported is also not a bug. This occurs when no content is entered in the "Only custom thread fields" editor in the admin panel. Nevertheless, we've made the necessary adjustments to enhance the user experience, and empty values will no longer be displayed as "null".
Additionally, with our recent updates, all custom thread fields you create will now be visible in the tooltip preview window that appears when hovering over thread titles.
Our products will be updated as soon as possible. Once the updates are completed, you can download the new versions from your license page. ;)
Important Reminder: If you encounter any issues or have suggestions regarding our products, please use our support ticket system. This allows us to provide you with faster and more effective solutions to your concerns.
XenForo 2.2.x XenForo 2.3.x
18.75 $
