Styles Ryzer Pro 2.2.8.1
Ryzer Pro
It has exciting features and excellent code quality.It has been designed and developed after thorough research to cater the requirements of people who interested in building user based directories. The design is contemporary but at the same time it focuses on the usability, visual hierarchy and aesthetics to ensure easy navigation for the end users.
65.00 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi Sürümler (16) İncelemeler (1)
Ryzer Pro için XenTR kullanıcısı yeni bir güncelleme yayınladı.
Ryzer Pro 2.2.8.1
This brings our styles up-to-date with XenForo v2.2.8 Patch 1
Please follow the update change log. You may download the update with a valid license.
Info:
With this update, the style modifier feature is built into the style properties. There is no longer any need to install the add-on in this link.
Customers who have previously purchased this design should first uninstall the add-on mentioned above. Instead, they can use this feature included in the theme.
You can find this property in the style properties. ↓├ XenTR ┤ Style changer
Before Upgrading
  • All templates have been updated for XenForo v2.2.8 Patch 1.
  • Fixed the issue where the multi-add button was not active while sending a message.
  • Fixed indentation issue in forum titles on mobile devices.
  • It is no longer necessary to install the style changer add-on externally. The style changer is included in the theme's own features.
Paras
New member
28 Ara 2021
How to update? Should I overwrite my style?
Paras
New member
28 Ara 2021
Thanks to Style changer option, it's more easier for user to choose the style.
XenForo 2.1.x + XenForo 2.2.x
65.00 $
