Jumbled slider
Occasionally when I navigate away from my forums while leaving the tab open in the background, the slider briefly appears jumbled if I return back to the tab after several minutes:
Oblivion Knight ;
Could you please let me know do you use any 3th party add-on or service provider to minify JS files. (Like as Cloudflare)
Thank you for your feedback, We will check the add-on release.
Stay safe my friend.
Definitely no third-party add-on, and I'm pretty sure I don't use a third-party service provider (definitely don't use Cloudflare).
The only thing I've changed from standard are the colours, and the padding to accommodate my larger avatars.. If I have chance tomorrow, I'll see if I can replicate it on your site at all.
I'm wondering if this is due to using the option "Karart"? I have swapped to "Yukarı kaydır" to see if the same thing occurs..
These phrases should be translated for the next release.. ?
  1. xentr
