Styles Innovate Light 2.2.1
Innovate Light
Innovate Light is a professional, flexible, fully-responsive forum theme for XenForo with a design and retina-ready graphics that is compatible with the most popular XenForo extensions.
10.00 $
Genel Bakış Telif Hakkı Bilgisi System Requirements Sürümler (24)
A new update is available for Innovate Light by XenTR.
  • XenForo 2.2.1 compatibility
  • All templates are now compatible with XenForo's 2.2.1 Release.
  • Style now supports loading from archive.
10.00 $
