A new update is available for [XTR] Watermark Pro by Official.
Previously, administrators observed identical images on the test pane because the simulation relied on a temporary file that lacked actual XenForo attachment metadata (
This version introduces an internal behavioral adaptation in the core Watermark Service layer. It now reliably bypasses restrictive environment validations exclusively during test runs, ensuring that you can predictably and immediately preview your customized watermarks without actually committing a real image database record to your forum.
[XTR] Watermark Pro 1.0.3
This maintenance release addresses a logical edge case involving the "Test Watermark" preview system within the Admin Control Panel.Previously, administrators observed identical images on the test pane because the simulation relied on a temporary file that lacked actual XenForo attachment metadata (
AttachmentData). As a result, the backend engine quietly skipped the watermarking procedure to faithfully comply with content-type validity checks and exclusion filters, even though the add-on continued to work normally on front-end uploads.This version introduces an internal behavioral adaptation in the core Watermark Service layer. It now reliably bypasses restrictive environment validations exclusively during test runs, ensuring that you can predictably and immediately preview your customized watermarks without actually committing a real image database record to your forum.
- Fixed: Resolved an issue in the Admin Control Panel where the "Test Watermark" tool inadvertently rendered identical original and watermarked comparison images.
- Changed: Enhanced the core
Servicelayer to conditionally enforce watermark application recursively without requiring strict database attachment constraints during tests.
