Add-Ons [XTR] Tools Suite
A new product by XenTR is available: [XTR] Tools Suite 1.0.0 - 20+ professional web tools for XenForo 2.3.x. DNS, SSL, SEO, security and more in one addon!
Description​
XENTR Tools Suite is a comprehensive addon package developed specifically for XenForo 2.3.x forum software, featuring 20+ professional web tools. Designed for webmasters, developers, and SEO specialists, these tools are built to speed up your daily workflow and simplify technical analysis.
The addon offers category-based organization, user-based daily quota management, detailed usage logs, and full control via the admin panel. Each tool is presented with a modern, user-friendly interface.
🔧 Tool List
🌐 DNS & Network Tools
  • DNS Lookup - Query A, AAAA, NS, MX, SOA, TXT, CNAME, SRV, CAA, DS, NAPTR, TLSA records. Includes DNSSEC analysis and security score.
  • WHOIS Lookup - View domain registration info, nameservers, registration/expiration dates.
  • MX Lookup - Check mail exchange records and priority values.
  • SPF Lookup - Analyze Sender Policy Framework records, verify email sending permissions.
  • DKIM Lookup - Query DomainKeys Identified Mail records, verify email signature authentication.
  • DMARC Lookup - Analyze DMARC policies, check email authentication settings.
  • IP Geolocation - View geographic location, ISP info, and timezone for IP addresses.
  • Port Scanner - Scan open ports on a host, discover service information.
  • Ping Tool - Measure server response time, check packet loss rate.
  • Ping Trace / Traceroute - Trace network path, measure response time for each hop.
🔒 Security Tools
  • SSL Checker - Check SSL/TLS certificate details, validity dates, issuer info, and certificate chain.
  • Blacklist Check - Check if your IP or domain is on spam blacklists. Queries 50+ blacklist databases.
  • Headers Check - Analyze HTTP response headers, check security headers (HSTS, CSP, X-Frame-Options, etc.).
  • Site Analysis - Analyze overall website security status, view open information and server details.
📊 SEO & Performance Tools
  • SEO Analysis - Analyze meta tags, heading structure, image optimization, internal/external links. Get SEO score and recommendations.
  • Site Speed Test - Measure website loading time, view performance metrics.
  • Broken Link Checker - Detect broken links on web pages, view HTTP status codes and anchor texts.
  • Robots.txt Generator - Create robots.txt files for search engines, define crawl rules.
  • Domain Availability - Check domain availability, learn availability for popular TLDs.
🛠️ Developer Tools
  • Base64 Encode/Decode - Encode or decode text data in Base64 format.
  • Password Generator - Generate secure, random passwords. Customize with length and character options.
  • Version Calculator - Compare XenForo and addon versions, check update status.
  • CSS to LESS Converter - Convert CSS code to XenForo LESS format. Auto-suggests XenForo variables with style property integration.
✨ Addon Features
  • Category System - Organize tools in hierarchical categories. Drag-and-drop sorting.
  • User Quota Management - Set daily query limits for each user group. Define separate quotas for each tool.
  • Protected URL List (Whitelist) - Protect your own domains, prevent unauthorized scanning.
  • Detailed Usage Logs - Log every query with user, target, IP address, and timestamp. View from admin panel.
  • Automatic Cleanup - Automatically clean old log records. Configure retention period.
  • Widget Support - Community statistics, popular tools, recently used tools, and user statistics widgets.
  • API Support - RESTful API for external integration. Read and Write scopes.
  • Multi-Language Support - All text managed via phrase system.
  • Responsive Design - Mobile-friendly interface, perfect on every device.
  • Admin Panel - Tool and category management, user logs, rebuild operations, export/import.
📦 Package Contents
  • 20+ Professional Web Tools
  • Category Management System
  • 4 Widgets (Community Stats, Popular Tools, Recent Tools, User Stats)
  • RESTful API
  • Admin Panel
📝 Legal Notice
This addon should only be used for legal purposes. By using the tools, you declare that you have permission from the target system owners and are acting in accordance with local laws. Unauthorized scanning and testing may be illegal.
DEMO:
For more information, please visit the link below.
Extended Product Information​
  • 20+ professional web tools (DNS, SSL, SEO, security, developer tools)
  • Category-based organization system (hierarchical tree structure)
  • User group-based daily quota management
  • Protected URL list (Whitelist) to prevent unauthorized scanning
  • Detailed usage logs (user, target, IP, timestamp)
  • Automatic log cleanup (configurable retention period)
  • 4 widgets (Community Stats, Popular Tools, Recent Tools, User Stats)
  • RESTful API support (read/write scopes)
  • Multi-language support (phrase system)
  • Responsive and mobile-friendly design
  • Admin panel (tool/category management, log viewing, rebuild)
  • Export/Import support (tool definitions)
  • Full XenForo 2.3.x compatibility
  • PHP 8.0+ support
A new update is available for [XTR] Tools Suite by Official.
[XTR] Tools Suite 1.0.1
The issue of “0 ms connection refused” that occurred on some servers while running site analysis or related tools has been resolved. The overly strict TLS and HTTP/2 requirements in request handling have been relaxed, allowing for a more universal and compatible connection standard.
  • Fixed: Resolved the permission issue where guest (unregistered) users were blocked from viewing tools and categories despite having the correct permissions.
  • Fixed: Addressed the "Failed to connect to port 443" cURL connection error occurring during Site Analysis on local development environments and specific server setups.
  • Updated: Improved the Cloudflare bypass (Localhost Resolve) logic to prevent IP conflicts when testing live domains from a local development environment.
  • Updated: Relaxed strict TLS cipher restrictions and forced HTTP/2 requirements in cURL requests to ensure broader server and OpenSSL compatibility.
  1. forum stats
  2. Seo analysis
