Add-Ons [XTR] Temporary Sticky Threads
  • Konuyu başlatan Konuyu başlatan Offical
14 Ara 2024
A new product by XenTR Offical is available: [XTR] Temporary Sticky Threads 1.0.0 - Smart management of sticky threads with automatic expiration
Description​
Manage Your Sticky Threads Intelligently!
[XTR] Temporary Sticky Threads is a powerful XenForo add-on that allows forum administrators and moderators to make threads sticky for a specific period of time. No more wondering "How long should this thread stay sticky?" Our add-on automatically reverts threads to normal status when the specified time expires and sends notifications to relevant parties.
  • More Organized Forum Appearance: Keep only truly important threads sticky for just the required duration
  • Time-Saving: No need to manually track and remove sticky status
  • Automatic Notifications: Stay informed through automatic alerts when sticky duration is about to expire or has expired
  • Flexible Management: Configure settings separately for each forum section
  • Easy to Use: Intuitive interface, set temporary sticky with just one click
The [XTR] Temporary Sticky Threads add-on is exactly the solution you need to make your forum more efficient and organized!
Extended Product Information​
Features and Advantages​
  • ✅ Time-Based Sticky Threads: Make threads sticky for a specific period in hours, days, weeks, or months
  • ✅ Automatic Unsticky: Threads automatically revert to normal status when the time expires
  • ✅ Comprehensive Notification System: Various notifications for sticky threads:
  • Notification to thread owner when thread is made sticky
  • Notification to admin who made it sticky when status is removed
  • Notification to moderators and thread owner before sticky duration expires
  • Automatic notifications when sticky duration expires
  • ✅ Admin Control Panel: Manage all temporary sticky threads from one place
  • ✅ Bulk Actions Support: Perform actions on multiple temporary sticky threads at once
  • ✅ Forum-Based Activation: Choose which forum sections have the temporary sticky feature enabled
  • ✅ Permanent/Temporary Option: Flexibility to make threads permanently sticky or for a specific duration
  • ✅ Notification Timing Setting: Determine how many hours before expiry notifications should be sent
  • 🔄 Cron Integration: Full integration with XenForo's cron system for automated processes
  • 🔍 Filtering and Search: Filter temporary sticky threads by forum, status, or title
  • 🛠️ XenForo 2.3.x Compatibility: Optimized for the latest XenForo version
  • 📱 Fully Responsive: Works seamlessly on mobile devices
  • 🔧 Performance Focused: Minimal server resource usage
  • 🌐 Multi-Language Support: Easily translatable to different languages
Add-on Settings and Configuration​
General Settings:
  • Enabled Forums: Select which forum sections will have the temporary sticky feature active
  • Notification Timing: Set how many hours before expiry notifications should be sent (0 = disable notifications)
The add-on provides a dedicated management page integrated into the XenForo admin panel:
  • View all temporary sticky threads on a single page
  • Filter threads by forum, expiry status, or title
  • Edit and extend duration information
  • Remove sticky status completely or make it permanent
  • Perform bulk actions (delete, extend duration, make permanent)
Usage Scenarios​
  • Announcements: Keep important announcements sticky until a specific event or process is completed
  • Events: Create threads that will automatically unsticky when the event ends
  • Contests: Keep threads sticky during contest duration and automatically revert to normal view when finished
  • Seasonal Content: Easily manage threads that need to remain sticky for a specific season
  1. language
