[XTR] Resource Downloaders Pro 1.1.3
In this release ACP-Resource search filters and criteria revised and added new phrases.
  • Added resource manager sort filters.
  • Search criteria updated.
  • Added new phrases.
Hello good night, we hope soon compatible with 2.2.x thanks
Happy So Excited GIF
A new update is available for [XTR] Resource Downloaders Pro by XDinc.
[XTR] Resource Downloaders Pro 1.1.1
XenForo 2.2.x and PHP 8.1+ Compatibility Update
We had to hard work on this version for a long time, with many radical changes.
  • Confirm XF 2.2.8+ Support
  • PHP 7.4+ compatibility.
1.1.1 Changelog
Options
Following general options have been added.
  • Enabled daily resource download limit information button
  • Added Download limit button information URL
  • Select daily limit information block style
  • Enabled daily resource download limit page
Permissions
Following user group permissions have been added.
  • Enforce post limit to download any resource
  • Can bypass post limit to download any resource
  • Enforce solution limit to download any resource
  • Can bypass solution limit to download any resource
  • Enforce reaction limit to download any resource
  • Can bypass reaction limit to download any resource
  • Can bypass enforce react to a resource before download
  • Enforce resource limit to download any resource
  • Can bypass resource limit to download any resource
  • Can view the daily download resource limit page
Hello team
the price ribbon not show for physical products or any products, except when I choose the external purchase!
how can I make the price ribbon appear for resources that purchased inside my site
thank you
Hello, This topic is only for [XTR] Resource Downloaders Pro updates and feedback. If you are asking about this product, you do not have a license for it.
If you are asking about your other license, the [XTR] DragonByte eCommerce Layouts addon, please open a support request for it. Also, we can't see what the problem is because your website is closed to visitors.
Please contact us through the support request for any issues you are experiencing. To help you faster, please share your temporary login information with us.
Regards...
I'm so so sorry
I wrote this issue in the late time and appear that I was not focusing
I post ticket
thank you
Resource Downloaders Pro v1.1.1 XenForo v2.2.17 ile hala tam uyum sağlıyor mu ?
Birde günlük indirme limiti (Daily resource download limit) kullanıcılar neye göre sıfırlanıyor ?
Yani, son indirilen dosyanın gün ve saatinden 24 saat sonra mı yoksa gece 12'den sonra mı?
Eğer geçe 12'den sonra sıfırlanıyorsa, hangi saat baz alınıyor ? Kullanıcının tarayıcı saati mi, sunucu saati mi ?
Çünkü bir günlük 3 adet indirme yetkisi olan (kullanıcı gurubunda belirlenmiş) kullanıcım yazdı bana, 28.02. tarihinde 3 dosya adet indirmiş, bu gün 01.03. tarihinde tekrar dosya indiremiyormuş.
A new update is available for [XTR] Resource Downloaders Pro by Offical.
[XTR] Resource Downloaders Pro 1.1.2
This update includes a comprehensive revision to ensure full compatibility with XenForo 2.3.x. All macro structures have been adapted to the new template system, and jQuery code has been replaced with vanilla JavaScript — completely eliminating the jQuery dependency.
As the "Featured Resource Slider" is now natively included in XenForo 2.3, the plugin’s version has been removed to prevent redundancy. Additionally, fixes have been applied to broken FA icons, widget structures, and the listing issue in the "Most Downloaded Resources" widget. The "Daily Download Limits" page has also been updated to match the new architecture.
This release marks a key step forward in terms of performance, stability, and long-term compatibility.
Support:
If you need assistance, feel free to contact us or create a support ticket.
We are always here to assist our customers and are happy to help resolve any issues you may encounter.
  • Full compatibility with XenForo 2.3.x has been ensured.
  • All template macros were adapted to XenForo 2.3.x structure.
  • jQuery code replaced with vanilla JavaScript — removed jQuery dependency.
  • Fixed broken Font Awesome icon issues.
  • Featured Resource Slider feature removed (now built into XenForo 2.3.x).
  • Adjustments made to various widget structures.
  • Updated the Daily Download Limits page.
  • Fixed the issue with resource listing in [XTR] Most Downloaded Resources widget.
  • All template modifications revised for XenForo 2.3.x compatibility.
[XTR] Resource Downloaders Pro için @Offical kullanıcısı yeni bir güncelleme yayınladı.
In this release, we’ve addressed an issue that was preventing the Most Resource Downloaders widget from rendering correctly on some systems. A template error caused by the $oldestMonth variable being undefined has been fixed. The widget now functions reliably under all conditions.
Support:
  • Bug fix: Fixed an `Undefined variable` error for `$oldestMonth` in the widget rendering logic.
