Add-Ons [XTR] Resource Downloaders Pro 1.1.2
  • Konuyu başlatan Konuyu başlatan Offical
This add-on allows you to view the resource downloading logs and set to resource download limits for each user groups
40.00 $
30.00 $
60.00 $
45.00 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements Sürümler (5)
14 Ara 2024
A new update is available for [XTR] Resource Downloaders Pro by Offical.
This update includes a comprehensive revision to ensure full compatibility with XenForo 2.3.x. All macro structures have been adapted to the new template system, and jQuery code has been replaced with vanilla JavaScript — completely eliminating the jQuery dependency.
As the "Featured Resource Slider" is now natively included in XenForo 2.3, the plugin’s version has been removed to prevent redundancy. Additionally, fixes have been applied to broken FA icons, widget structures, and the listing issue in the "Most Downloaded Resources" widget. The "Daily Download Limits" page has also been updated to match the new architecture.
This release marks a key step forward in terms of performance, stability, and long-term compatibility.
Support:
If you need assistance, feel free to contact us or create a support ticket.
We are always here to assist our customers and are happy to help resolve any issues you may encounter.
  • Full compatibility with XenForo 2.3.x has been ensured.
  • All template macros were adapted to XenForo 2.3.x structure.
  • jQuery code replaced with vanilla JavaScript — removed jQuery dependency.
  • Fixed broken Font Awesome icon issues.
  • Featured Resource Slider feature removed (now built into XenForo 2.3.x).
  • Adjustments made to various widget structures.
  • Updated the Daily Download Limits page.
  • Fixed the issue with resource listing in [XTR] Most Downloaded Resources widget.
  • All template modifications revised for XenForo 2.3.x compatibility.
XenForo 2.1.x XenForo 2.2.x XenForo 2.3.x
40.00 $
30.00 $
60.00 $
45.00 $
