Add-Ons [XTR] Random Tips 1.0.10
[XTR] Random Tips
The Random Tips add-on is allows you to show an unlimited number of random tips on your website.
$30.00
$22.50
1 Year
$45.00
$33.75
Add-On Branding Removal
Overview Feature list Copyright info System Requirements Releases (11) Reviews (1)
A new update is available for [XTR] Random Tips by Offical.
This is a maintenance release that addresses critical bugs reported in version 1.0.9.
Search Form Fix
We resolved a server error that occurred when attempting to search for tips. The missing search form template has been added, restoring full search functionality.
Widget Fixes
We've improved the upgrade process to ensure the Random Tips widget is correctly created for all users, fixing the "Widget definition missing" error. We also added missing phrases for the widget definition in the Admin CP.
Upgrade Notes
  • Safe to upgrade directly from any previous version.
  • No database schema changes, only template and phrase updates.
[*] Bug Fixes
  • Fixed: Missing "search_form_xentr_tip" template causing "Template public:search_form_xentr_tip is unknown" error when searching tips.
  • Fixed: "Widget definition missing" error for some users upgrading from older versions. Added widget definition phrases.
[~] Improvements
  • Improved upgrade stability: Added checks to ensure the widget is automatically created if it's missing during upgrade.
  • Added missing widget definition phrases to ensure proper display in Admin CP.
XenForo 2.1.x XenForo 2.2.x XenForo 2.3.x
78
5.00 star(s) 1 ratings
$30.00
$22.50
1 Year
$45.00
$33.75
