Add-Ons [XTR] Most Resource Downloaders
A new product by Ovunc Dinc is available: [XTR] Most Resource Downloaders 1.0.0 - This addon allows you to display the most resource downloaders of the month.
Description
EN:
This add-on displays a selectable number of users with the most resource downloaders of the month (month and year are selectable) on a widget and a special page like as Most resources.
Also add-on allows you to display the total number of resources downloaded for each user in the user profile and in the user area.
TR: Bu eklenti en çok kaynak indiren kullanıcıları bir widget ve özel bir sayfada belirlenen tarih bazında görüntülemenizi sağlar.
Ayrıca her bir kullanıcı için toplam indirdikleri kaynak sayısını kullanıcı profilinde ve kullanıcı alanında görüntüler.
Furthermore the result can be filtered:
Exclude user groups
Exclude user
Widget with 3 Styles
Options
mrdownloaders-options-png.3424
You can select different display option to the User Extras of MRD Widget
mrdownloaders-options-userextras-png.3425
Widget style
mrdownloaders-widget_style-png.3426
Style Properties
mrdownloaders-styleproperties-png.3427
Widget
mrdownloaders-widget-png.3428
Page
Most resource downloaders page
mrdownloaders-page-png.3429
Downloads Count
User info
mrdownloaders-download_count_user_info-png.3431
Member Profile
mrdownloaders-download_count_profile-png.3430
Permissions
mrdownloaders-perm-png.3432
Note: When you install the add-on please run the cron. (This step will calculate the number of downloads per user.)
mrdownloaders-cron-png.3433
You can configure the cron schedule as you wish.
Extended Product Information
  • User of the month X and year Y
  • Total download count
  • Exclude user groups
  • Exclude User
  • Permission based
  • Style properties
Kardeşim ellerine sağlık. Kaynak takibi yapmak isteyen yöneticiler için harika bir eklenti . Widget olarak kullanılabiliyor olması is ayrı bir güzellik. ;)
