Add-Ons [XTR] IP Threat Monitor 1.0.9
IP Threat Monitor is a professional security addon that protects your XenForo forum from malicious bots, DDoS attacks, and excessive request traffic. With its cache-first architecture, it reduces database load by 98% while delivering 5-10x faster response times. SEO-friendly design protects search engines while never affecting your real users' experience.
30.00 $
22.50 $
37.50 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements FAQ Sürümler (10)
14 Ara 2024
This update focuses on improving stability and refining the user experience. With critical fixes to the installation infrastructure, we ensure the add-on runs smoothly in all environments.
Highlights:
  • Robust Installation: Eliminated potential issues with database schema creation during fresh installs and upgrades.
  • Full Multi-Language Support: The "Test Configuration" page in the Admin CP is now fully phrased and translatable. Hard-coded text has been removed.
  • Smarter Diagnostics: The system self-test tool now intelligently analyzes your server configuration, preventing false positives regarding cache settings.
We recommend all users upgrade to this version.
  • [Fix] Resolved an issue where the xentr_ipt_country column was not being created in the xf_user table during fresh installations (Fixed step ordering in Setup.php).
  • [Fix] Fixed the Cache Logic in "Test Configuration" page where "Direct DB Mode" (when Redis/APCu is unavailable) was incorrectly reported as a failure. It is now recognized as a valid passing state.
  • [Fix] Corrected a layout alignment issue with status icons in the admin test results.
  • [Refactor] Replaced all hard-coded strings in the "Test Configuration" page with XenForo phrases, ensuring full multi-language support.
30.00 $
22.50 $
37.50 $
