Add-Ons [XTR] IP Threat Monitor 1.0.7
IP Threat Monitor is a professional security addon that protects your XenForo forum from malicious bots, DDoS attacks, and excessive request traffic. With its cache-first architecture, it reduces database load by 98% while delivering 5-10x faster response times. SEO-friendly design protects search engines while never affecting your real users' experience.
$30.00
$22.50
1 Year
$50.00
$37.50
Overview Feature list Copyright info System Requirements FAQ Releases (22)
This update brings a major leap in both usability and protection capabilities! The admin panel is now cleaner, and blocking capabilities are more precise than ever.
🌟 Feature Highlights​
1. Modern Tabbed Interface:
No more endless scrolling! All options are now organized under logical tabs. Finding the setting you need takes just seconds.
2. ASN Blocking (Stop the Bots!):
Beyond simple IP blocking, you can now block entire network providers based on their ASN.
Example: You can block entire data centers hosting AI scrapers (e.g., specific DigitalOcean or AWS ASNs) in one go.
3. Country Flags 🇺🇸:
See where your users are connecting from at a glance. Country flags are now automatically displayed next to usernames in posts. (Integrated seamlessly with the VPN detection system).
4. iCloud Private Relay Friendly:
Don't lose real users! Added a new option to whitelist traffic from Apple iCloud Private Relay, ensuring legitimate Apple users aren't blocked by VPN filters.
Update Note:
After upgrading, it is recommended to run the "Test Configuration" tool in the Admin Panel to verify that the database schema and settings are correctly applied.
  • Refactored options page into a tabbed layout (General, Rate Limit, VPN & ASN, Exemptions).
  • Added ASN (Autonomous System Number) based blocking system.
  • Added Country Flags display in user postbit information.
  • Added xentr_ipt_country column to xf_user table.
  • Added option to white-list Apple iCloud Private Relay traffic.
  • Fixed array/string conversion error in Blocked ASN list input.
  • Refactored Setup.php structure (Install/Upgrade/Uninstall) for better maintainability.
  • Updated Test Configuration tool to include database schema checks and new feature validation.
Osman abi, bu eklentinin grafikler kısmına en çok engellenen 5 ülke gibi parametreleri ekleme şansın olur mu?
Buna ilaveten, sonraki versiyonda admin panele özel güvenlik ekleyebilir misin? Bu eklenti doğrudan genele açık forum alanını kontrol ediyor bildiğim. Admin paneline özgü forumdan farklı derece ayarlayabileceğimiz birşeyler düşünülebilir mi? Forumda daha esnek bir ayar tercih edebilecekken admin panelde daha agresif bir tutum sergilemek iyi olabilir.
Bu isteyeceğim bu eklentinin kapsamı dışına çıkabilir belki ama özellikle admin paneline giriş için panele girebilecek IP ler gibi bir ilave fonksiyonda hoş olabilirdi. Özellikle statik IP kullanmayı tercih edenler için güzel bir ilae olurdu bu.
Açıkçası Cloudflare ı iptal edip bunu kullanmayı ciddi anlamda düşünüyorum.
Gözümden kaçmış olabilir resimlerde göremedim. Ülke IP engeli de bir başka güzel fonksiyon olabilir. Belirlenen bazı ülkelerden girişler doğrudan enellenebilir belki. Tabi bu engellenen ülkelerden gerçek bazı ziyaretçiler ulaşıp giriş izni isterse nasıl bir ayar uygulanabilir emin değilim.
Fatih bey önerileriniz için teşekkür ederim. Eklentiyi Cloudflare'e alternatif olarak düşünecek kadar beğenmeniz beni ayrıca mutlu etti!
Ancak beklentileri doğru yönetmek adına dürüst bir açıklama yapmak isterim:
Cloudflare ve Uygulama Güvenlik Duvarı Farkı: Cloudflare trafiği Ağ Kenarında (sunucunuza gelmeden) engeller. Bu eklenti ise Uygulama Seviyesinde (istek sunucuya ulaştıktan sonra) çalışır. Bu nedenle Cloudflare'ı iptal etmek yerine, ikisini birlikte kullanmanızı şiddetle öneririm. Büyük saldırıları sadece uygulama seviyesinde karşılamak sunucu kaynaklarınızı tüketebilir.
Özellik isteklerinize gelince:
  1. Top 5 Ülke Grafiği: Bu güzel bir görsel detay. Gelecek değerlendirmeler için notlarıma ekledim.
  2. Admin Paneli Kısıtlamaları: Admin paneli erişimini bir eklenti üzerinden kısıtlamak, yanlışlıkla kendinizi kilitleme riskini taşır. Admin paneli güvenliği özellikle Statik IP izni vb için sunucu seviyesinde .htaccess kurallar kullanmak her zaman daha güvenli ve performanslıdır.
  3. Ülke Engelleme: Yeni eklediğimiz ASN ve VPN engelleme özellikleri, belirli bölgelerden gelen istenmeyen trafiğin (botlar ve proxy'ler) büyük kısmını zaten durdurmaktadır.
Şu an için önceliğim eklentiyi kararlı ve stabil tutarak sorunsuz çalışmasını sağlamaktır. Çok fazla karmaşık katman eklemek, sistemin işleyişini ve kullanım kolaylığını olumsuz etkileyebilir.
133
$30.00
$22.50
1 Year
$50.00
$37.50
