Add-Ons [XTR] IP Threat Monitor 1.0.5
  • Konuyu başlatan Konuyu başlatan Offical
IP Threat Monitor is a professional security addon that protects your XenForo forum from malicious bots, DDoS attacks, and excessive request traffic. With its cache-first architecture, it reduces database load by 98% while delivering 5-10x faster response times. SEO-friendly design protects search engines while never affecting your real users' experience.
30.00 $
22.50 $
37.50 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements FAQ Sürümler (7)
14 Ara 2024
This update introduces a new "VPN Check Mode" setting that gives you control over when VPN/Proxy checks are performed. You can now choose between minimal API usage (Aggressive), balanced approach (Moderate - recommended), or maximum protection (First Visit).
An important bug fix resolves an error that occurred when checking IPv6 addresses such as Cloudflare IPs.
New
  • Added "VPN Check Mode" option with 3 modes: Aggressive, Moderate, and First Visit
  • Moderate mode allows balanced API usage while maintaining security
  • First Visit mode provides proactive VPN detection for high-security sites
Fixed
  • Fixed IPv6 address validation error ("String offset cast occurred")
  • Cloudflare IPv6 addresses are now properly checked against IP ranges
Improved
  • Test Configuration page now includes VPN detection status
  • Test Configuration shows VPN Check Mode with API usage warnings
  • Added recommendation when "First Visit" mode uses high API quota
30.00 $
22.50 $
37.50 $
