Add-Ons [XTR] IP Threat Monitor 1.0.21
IP Threat Monitor is a professional security addon that protects your XenForo forum from malicious bots, DDoS attacks, and excessive request traffic. With its cache-first architecture, it reduces database load by 98% while delivering 5-10x faster response times. SEO-friendly design protects search engines while never affecting your real users' experience.
$30.00
$22.50
1 Year
$50.00
$37.50
Overview Feature list Copyright info System Requirements FAQ Releases (27)
Critical Fixes & Improvements
This update introduces a major architectural change to the caching mechanism, migrating from database-based storage to a dedicated file-based system to permanently resolve database size limits.
  • Fixed: Resolved the critical "MySQL Data too long" error caused by large IP lists exceeding database capacity.
  • Fixed: Database performance issues caused by frequent updates from the Rate Limiter and IP services.
  • Changed: The caching system has been completely rebuilt to use file-based storage instead of the database, ensuring zero database load for large datasets.
  • Improvement: Optimized cache cleaning processes for better stability.
Since version 1.0.20, I've been experiencing an issue where I can't switch tabs in the admin settings when I click on them. I just discovered, after translating the phrases into German, that this only happens in the German language. Do you have any suggestions on where I might be looking for the correct phrases to check if I've entered something incorrectly? Oddly enough, it worked fine up until version 1.0.19 (in German). And the phrases haven't been changed since then, have they?
is working....
cannot switch through the tabs...
Ahhh forgot. If I use the settings switch from the add-on menu (german language is selected) is works, too.
It's only if I try to use it from the list onj the left (settings)
1.21 crashed my site, exhausted the memory usage on my site through NGINX which had to shut itself down because of this. When I disable the addon it stops doing this, though its very hard to catch the site in a moment where I can switch it off because of NGINX being down. This also crashes my connection via SSH.
Additional Request: Ability to turn of the alert that goes out to staff, there is a fair bit of alert SPAM going on for me. Also I am getting a lot of blacklisted IP's however I am still getting smashed with malicious traffic and most of it bot traffic
Thank you for your feedback. In order to properly analyze the issue and identify the root cause, I kindly ask you to provide more detailed information via a support ticket, including the following:
  1. Detailed description of the issue
    • When and under which action the issue occurs
    • Whether the problem is consistent or intermittent
  2. Steps to reproduce
    • A step-by-step description of the path you follow to trigger the issue
    • Which admin menus or settings pages are involved
  3. Screenshots / error messages
    • Screenshots of any error messages you encounter
    • Browser console errors, if available
  4. Language / environment details
    • Active forum language
    • XenForo version
    • PHP version and server setup
  5. (Optional but highly appreciated)
    • If possible, please provide a temporary administrator account so I can directly inspect the issue on your website, which will significantly speed up troubleshooting.
This information will help determine whether the issue is related to the add-on itself, language phrases, or the server/environment configuration.
Thank you for your cooperation.
I ended up having to rollback to a backup of the server because everything went real bad.
I will take a snapshot of my server now and then re-install this version so I can capture logs etc if it happens again. Then happy to give you temp admin too,
I appreciate that its going to be difficult to troubleshoot this one without logs. From what I can tell is that the new caching mechanism seemed to cause a lot of memory consumption which essentially made the system kill nginx.
Ill sort that out today and capture some logs as well
280
$30.00
$22.50
1 Year
$50.00
$37.50
