Highlights:
No database schema changes are required. Safe to upgrade on production environments.
[XTR] IP Threat Monitor 1.0.15
This is a critical maintenance update highly recommended for all users, especially those with busy forums.Highlights:
- Database Scalability Fix: We identified a limitation in XenForo's native SimpleCache system where storing thousands of VPN check results caused a "Data too long" database error on high-traffic sites. We have refactored the caching logic to separate these high-volume records into our own CacheManager system. This ensures your site runs smoothly regardless of how many IPs are being monitored.
- New Maintenance Tool: A new tool in the Admin Panel allows you to specifically clear the VPN check cache. This is useful if you want to re-check previously scanned IPs against the API without clearing your entire log history.
- Reliability Improvements: Fixed a typo in the iCloud Private Relay logic to ensure Apple users are correctly identified and not blocked when exemptions are enabled.
- Critical Fix: Resolved
MySQL query error [1406]: Data too long for column 'data_value'. This issue occurred on high-traffic sites because XenForo's SimpleCache stores all data in a single database row, which overflowed with thousands of IP check records. VPN/Proxy check results are now securely stored using the add-on's efficient CacheManager (Redis/APCu/File) instead. - New Feature: Added "Clear VPN Check Cache" option to the Monitor Dashboard > Prune / Clear Logs page. Admins can now easily flush cached VPN/Proxy results to force re-validation of IPs without needing database queries.
- Bug Fix: Fixed a variable typo (
$ipvs$ipAddress) in the Apple iCloud Private Relay detection service that potentially hindered correct identification. - Technical: Optimized cache handling: Global API health status remains in SimpleCache for persistence, while high-volume per-IP validation data is moved to CacheManager for scalability.
