Management capabilities have been maximized with "Last URL Tracking" and "Smart Prune" features.
[XTR] IP Threat Monitor 1.0.10
This comprehensive update brings critical features to the add-on. The most notable addition is the "Flag Display" option, allowing you to show country flags for all visitors even in "Moderate" mode. Additionally, the "Geo-Blocking" feature is now available to block unwanted traffic from specific countries. The "Integrated Diagnostics Tool" has been extensively rewritten and now features,Management capabilities have been maximized with "Last URL Tracking" and "Smart Prune" features.
- [New] Check All Visitors: Added "Check all visitors for country flag" option. It is now possible to display country flags for all visitors regardless of the protection mode (Moderate/Aggressive).
- [New] Geo-Blocking: Added the "Blocked Countries" setting to permanently block all traffic from specified countries (e.g., CN, RU).
- [New] Integrated Diagnostics Tool (Revamped): Added a completely redesigned diagnostics tool with visual charts and Vanilla JS structure, compliant with XenForo 2.3 standards.
- [New] Last URL Tracking: Added the ability to see the Last URL and User Agent information of visitors/blocked IPs (via tooltip in Admin Panel).
- [New] Smart Prune: Introduced an optimized cleaning mode that removes old logs while preserving "Blocked" and "Blacklisted" records.
- [New] Comment Support: Support for comments using the '#' character has been added to the Blocked ASNs list.
- [Fix] Fixed a logic error where country/flag checks were skipped for Admins and Trusted users.
- [Fix] Fixed the "IP address is required" error that occurred when performing actions in Admin Panel IP lists.
- [Fix] Resolved various database and getter errors in Setup.php and User entity extension.
