Add-Ons [XTR] Extended Sticky Alerts 1.0.2
[XTR] Extended Sticky Alerts için @XDinc kullanıcısı yeni bir güncelleme yayınladı.
XenForo 2.2.x and PHP 8.1+ Compatibility Update
  • Confirm XF 2.2.8+ Support
  • PHP 8.1 compatibility update.
1.0.2 Changelog
  • Add-on templates updated to XF 2.2.8+.
  • The sticky alert repo is updated.
  • Template modifications are updated.
Required
  • XF 2.2.8+
  • PHP 8.0+
Note: Please do not install or upgrade the add-on, if you are using lower than XF 2.2.8.
This version only supports XF 2.2.8+ and PHP 8.0+
  1. sticky
