Add-Ons [XTR] AI Assistant 1.0.6
[XTR] AI Assistant
The ultimate AI integration for XenForo. Deploy intelligent bots powered by ChatGPT, Gemini, Claude and 400+ models. Features include mention replies, automated content creation, knowledge base (RAG), vision support, and image generation.
$45.00
$33.75
1 Year
$65.00
$48.75
Overview Feature list Copyright info System Requirements FAQ Releases (12)
A new update is available for [XTR] AI Assistant by Offical.
This release focuses on improving user experience with smarter button visibility and fixing the language detection for AI summaries.
Highlights
1. Smart Button Visibility
AI action buttons (Generate Image, Ask AI, Translate, Summarize, Reply Suggest) now intelligently hide in forums where no bot is configured to operate.
How to Configure:
  1. Go to Admin Panel → AI Assistant → Bots → Edit
  2. Navigate to the Access tab
  3. Select forums in the Reply forums field
  4. Save
If "Reply forums" is empty, the bot works everywhere. If specific forums are selected, buttons only appear in those forums.
2. Summarize Language Fix
The AI summary feature now correctly uses the user's selected XenForo language instead of sometimes responding in English.
3. Consistent AI Parameters
All AI features now properly use the bot's temperature and max_tokens settings from the Intelligence tab. Previously, some features used hardcoded values.
Upgrade Notes
  • Review your bot's "Reply forums" setting if you want forum-specific button visibility
New Features
  • Smart Button Visibility - AI action buttons now automatically hide in forums where no bot is available
  • Generate Image, Ask AI, Translate, Summarize, and Reply Suggest buttons respect forum permissions
  • Buttons only appear if the bot is configured to operate in that specific forum
  • New template function xentr_has_bot() for forum-based visibility checks
Improvements
  • Summarize Language Fix - AI now uses user's XenForo language for summaries instead of guessing
  • All AI functions now use bot's temperature and max_tokens settings from Intelligence tab
  • Removed hardcoded AI parameters for consistent behavior across all features
  • Simplified forum permission logic - now uses only "Reply forums" field from Access tab
Technical Changes
  • Added templater_setup event listener for custom template functions
  • Created Template/TemplaterSetup.php class for template helpers
  • Added hasAvailableBotForNode() method to BotRepository
  • Updated canOperateInNode() to use simplified logic
Bug Fixes
  • Fixed Summarize output being truncated due to hardcoded max_tokens value
  • Fixed ProfilePostCreator using incorrect property access for bot settings
  • Fixed inconsistent temperature values across different AI features
I'd like to say that the documentation and examples included in the app are amazing. So much detail and examples.
251
$45.00
$33.75
1 Year
$65.00
$48.75
