Add-Ons [XTR] AI Assistant 1.0.18
A new update is available for [XTR] AI Assistant by Offical.
[XTR] AI Assistant 1.0.17
With this update, we have focused on improving the robustness of AI outputs, fixing quote rendering issues, and expanding customization options for administrators based on your feedback.
Key Highlights in this Release:
  • Smart Citation Filtering: We have added a smart filter for research-augmented models like Perplexity and Sonar. Ugly, unclickable reference markers (like [1] or [1, 2]) that these models sometimes inject are now automatically stripped before rendering on the forum.
  • Media Rendering in Quotes: Fixed a critical issue where the AI would sometimes break MEDIA, IMG, or ATTACH BBCode tags when trying to quote a user. Orphaned or half-written tags generated by the AI are now properly cleaned up and sanitized.
  • Enhanced AI Persona Retention: Some AI models with shorter context windows tend to "forget" their assigned persona (e.g., "You are a friendly support assistant") as the conversation gets longer. We've added a strict reinforcement block to the end of the system prompt to guarantee your bot stays in character at all times.
  • New Admin Option for Thread Creation: You can now control the default behavior of the "Enable AI Bots" checkbox when users create new threads. By using the new "Enable AI Bots by default" option in the admin panel, you can choose to have it unchecked natively.
  • Fix: Added a specialized filtering method to automatically remove Perplexity/Sonar style footnote markers from AI output.
  • Fix: Implemented a sanitization step to purge unclosed or broken BBCode tags generated by AI models.
  • Fix: Improved the quoting logic to completely remove media tags from the shortened quote content, preventing broken embeds in the front end.
  • Enhancement: Added an "IDENTITY REMINDER" reinforcement block to the system prompt to prevent context loss for models.
  • Feature: Added a new global option to manage the default checked/unchecked state of the AI trigger on the thread creation page.
  • Update: Updated the thread creation template modifications to reflect the new dynamic checkbox option.
  1. xtr ai assistant
  2. Multi account
  3. openai
