Question Special Pro Menu Icons
  • Konuyu başlatan Konuyu başlatan Abhean
Abhean
9 Ara 2022
I was installing an addon and noticed that the normal icon did not appear on the menu.
Spoke with the creator (Bob) and he informed me that he does not code the icons to show on the menu, so I am reaching out to you.
I belive the Icon should be fa-star. Any advice of getting it to generate on the menu?
Hi;
Goto admin.php?navigation/
Enter the Font Awesome icon code you want as in the sample picture.
Example: fad fa-star
