Styles Special Pro 2.3.10
I just love Special Pro theme. You guys did a wonderful work on it and as I was told, each theme have is unique. I just love it.
BUT... as always exist a "but", I have a suggestion, why you guys don`t give us the opportunities to use pic icons instead of font awesome on nodes.
Will be a great improve. Thank you.
Thanks for your beautiful comment. Of course I understand you. There are various add-ons already made for forum icons on the official site. Many things can be integrated into the theme, but it will not be right to meet every request from a theme template.
Frankly, I can't promise this, but I will try to take your suggestion into consideration for future versions. ;)
  • Like
Reactions: EL
A new update is available for Special Pro by XenTR.
Special Pro 2.2.11
This update simply fixes a few minor bugs and addresses the outdated template that is appearing on the latest version of XenForo (v2.2.11).
Before Upgrading:
  • XenForo v2.2.11 compatibility
  • The add-on for the theme has been updated. (New version 1.0.3)
  • Added some missing language expressions
  • Google invalid characters bug fixed
How do I move the nav to the side from the top? I have looked at all the settings.
I'm trying to change the category colors on this theme; if I go into the node setting and make a change, nothing happens.
This feature only works if the selections in the image below are active. ;)
Special Pro 2.2.12
This update fixes a few minor bugs, also addresses the outdated template that is appearing on the latest version of XenForo v2.2.12
Before Upgrading:
  • XenForo 2.2.12 compatibility
I was installing an addon and noticed that the normal icon did not appear on the menu.
Spoke with the creator (Bob) and he informed me that he does not code the icons to show on the menu, so I am reaching out to you.
I belive the Icon should be fa-star. Any advice of getting it to generate on the menu?
Hi;
Goto admin.php?navigation/
Enter the Font Awesome icon code you want as in the sample picture.
Example: fad fa-star
Special Pro 2.2.13
  • XenForo v2.2.13 compatibility.
  • All templates are now compatible with XenForo v2.2.13 Release.
Special Pro 2.2.15
  • Upgraded to xenForo 2.2.15
A new update is available for Special Pro by XenTR Offical.
Special Pro 2.3.6
Bu güncellemeler, XenTR Special Pro temasının modern web standartlarına ve XenForo'nun en son sürümüne uyum sağlamasını amaçlıyor. Özellikle node resmi silme özelliği gibi kullanıcı deneyimini iyileştiren değişiklikler, forum yöneticilerinin içerik yönetimini daha verimli hale getiriyor. jQuery bağımlılığının kaldırılması ve PHP 8.x uyumluluğu, temanın geleceğe hazır olmasını sağlıyor.
Makro yapılarının yeniden yazılması ve LESS şablonlarının optimize edilmesi, temanın performansını artırırken bakım kolaylığı da sağlıyor. Bu, uzun vadede sürdürülebilirliği destekleyen önemli bir teknik iyileştirmedir.
These updates aim to align the XenTR Special Pro theme with modern web standards and the latest version of XenForo. Particularly, user experience enhancements like the node image deletion feature make content management more efficient for forum administrators. The removal of jQuery dependency and PHP 8.x compatibility ensure the theme is future-ready.
The rewriting of macro structures and optimization of LESS templates improve the theme's performance while providing ease of maintenance. This represents a significant technical improvement that supports long-term sustainability.
Sistem Uyumluluk İyileştirmeleri​
  • XenForo 2.3.x Uyumluluğu: Tema ve eklenti, XenForo'nun en son 2.3.x sürümüyle tam uyumlu hale getirildi
  • PHP 8.x Uyumluluğu: Sayısal değerlerle ilgili hatalar düzeltilerek PHP 8.x ile sorunsuz çalışma sağlandı
  • jQuery Bağımlılığının Kaldırılması: Modern JavaScript yaklaşımları kullanılarak jQuery bağımlılığı ortadan kaldırıldı
Kullanıcı Deneyimi İyileştirmeleri​
  • Node Resmi Silme Özelliği: Forumlara ve kategorilere yüklenen arka plan resimlerini kolayca silme yeteneği eklendi
  • Theme Customizer Güncellemesi: Renk seçiciler, XenForo 2.3.x yapısında sorunsuz çalışacak şekilde yeniden tasarlandı
  • LocalStorage/Cookie Hata Düzeltmesi: Kullanıcı tercihlerinin saklanmasıyla ilgili hatalar giderildi
  • Google SEO İyileştirmesi: datePublished meta verisiyle ilgili sorun çözülerek arama motoru görünürlüğü artırıldı
Teknik İyileştirmeler​
  • Font Awesome Simge Düzeltmeleri: Kırık FA simgeleri güncellenerek görsel bütünlük sağlandı
  • Makro Yapısı Yenileştirmesi: Tüm makrolar XenForo 2.3.x yapısıyla uyumlu olacak şekilde yeniden yazıldı
  • LESS Şablonları Optimizasyonu: Tema performansını artırmak için LESS şablonları düzenlendi ve optimize edildi
  • Controller İyileştirmeleri: Node resmi silme işlemi için güvenli ve modüler controller yapısı eklendi
Güvenlik İyileştirmeleri​
  • Güvenli Dosya İşlemleri: Node resimlerinin güvenli bir şekilde yüklenmesi ve silinmesi için gerekli kontroller eklendi
  • Hata Yönetimi: Beklenmedik durumlar için kapsamlı hata yönetimi mekanizmaları geliştirildi
System Compatibility Improvements​
  • XenForo 2.3.x Compatibility: Theme and add-on fully updated to be compatible with the latest XenForo 2.3.x version
  • PHP 8.x Compatibility: Fixed numerical value handling issues to ensure smooth operation with PHP 8.x
  • jQuery Dependency Removal: Eliminated jQuery dependency by implementing modern JavaScript approaches
User Experience Enhancements​
  • Node Image Deletion Feature: Added ability to easily delete background images uploaded to forums and categories
  • Theme Customizer Update: Color pickers redesigned to work seamlessly with XenForo 2.3.x structure
  • LocalStorage/Cookie Bug Fixes: Resolved issues related to storing user preferences
  • Google SEO Enhancement: Fixed datePublished metadata issue, improving search engine visibility
Technical Improvements​
  • Font Awesome Icon Fixes: Updated broken FA icons to ensure visual consistency
  • Macro Structure Revamp: All macros rewritten to be compatible with XenForo 2.3.x structure
  • LESS Templates Optimization: Edited and optimized LESS templates to improve theme performance
  • Controller Enhancements: Added secure and modular controller structure for node image deletion
Security Enhancements​
  • Secure File Operations: Added necessary checks for secure uploading and deletion of node images
  • Error Handling: Developed comprehensive error handling mechanisms for unexpected scenarios
A new update is available for Special Pro by Offical.
Special Pro 2.3.7
This update addresses template compatibility issues that occurred after the recent XenForo upgrade.
  • Fixed all outdated template issues caused by recent XenForo updates.
  • The display issue with Font Awesome icons in navigation menu layouts has been fixed.
Special Pro 2.3.8.0
This release includes minor bug fixes and ensures compatibility with XenForo 2.3.8.
It is intended only for XenForo 2.3 versions. No theme add-on update is required.
  • Minor bug fixes applied.
  • Updated for compatibility with XenForo 2.3.8.
Special Pro 2.3.10
This update resolves a progress bar display issue caused by compatibility problems with the [XTR] Smart Customization add-on. Additionally, the progress bar issue in the vertical layout has been fixed, ensuring consistent functionality across all layout types.
  • Fixed an issue where the progress bar was not displaying correctly when using the [XTR] Smart Customization add-on.
  • Resolved a problem where the progress bar did not work in vertical layout.
