Fixed Smart customize - double nodetype icons in front
Chris59
Revolution issue
Revolution style option you have the option
├ XenTR ┤ Node/Forum list​
you have this option for default nodetype icons. i have them activated and show double icons on front side
I would like to keep thoose icons because they look good two tones , but when i have thoose icons enabled its shows double on the front side , see photo below
the green ones is Revolution icons
the red ones is smart customize icons
and shows at same time on front end
Here is the Zenitho theme issue
Thank you for your feedback.
This issue occurs because the Revolution style has its own Node Icons system handled separately through its Style Properties.
  • If you prefer to use Revolution's Style Properties for node icons, then you should not define additional icons through the Smart Customization add-on. You may still add icons for main categories, but not for individual nodes.
  • Alternatively, if you'd like to use icons via Smart Customization, then you need to disable the Node Icons feature in Revolution’s Style Properties.
For the Zenitho theme:
Simply go to [XTR] Smart Customization > Node options tab > Node icon font size and set a suitable font size value.
Finally, please re-download and update the Revolution theme. This should resolve the issue you reported.
Yes i only use smart customizing for the node category icons . updated theme as well as you suggested and now all is perfectly
What a great support from you devs ⭐⭐⭐⭐⭐
Thanks / Chris
  1. xentr
