Styles Shadow
A new product by XenTR is available: Shadow 2.2.11 - Shadow is a great theme to help you build a website for Gaming Communities.
Shadow 2.2.11
Description
Shadow is mainly based on gaming, but it can be used in many other situations because it is very easy to customize, and it doesn't take long to turn it into a perfect template for your job.
It offers full admin control that will keep all members satisfied with the features. Your job is just to figure out which type of work you want to create and this shadow community theme will get it done with ease.
Extended Product Information
Multiple layouts and styles
  • Navigation location changes
  • 6 different background image options
  • You can use the liquid full-width version or the fixed size layout.
  • You can have multiple node layouts: dual colum or list view.
  • And more...
Main Features of Shadow
  • Links hover effect
  • Custom Scrollbar
  • Six different backgrounds
  • Toggle page width
  • Collapsible Categories
  • Icon or image for node icons
  • Navigation icons
  • Navigation hover effect
  • Remove Sub-navigation row
  • Notification icon effects
  • Sidebar icons
  • Three Different Forum Layouts
  • Show/Hide Breadcrumbs
  • Hide forum title in index page
  • "New" Indicator Label
  • Online/Offline status indicator in the discussion list
  • Advanced footer easily customized
  • Google Fonts
  • And more...
Kurdum siteye guzel oldu
Happy Bravo GIF by LIDL Romania
Tesekkurler ,kucuk sorun gordum konuya girince quicklink bolumu gorunmuyor. Resim attim, resimle daha iyi anlasilir diye. (home/forum yazan yer.)
Ilk resim shadow dan ikinci resim revolution dark dan
Eğer yanlış anlamadıysam Breadcrumb alanınındın söz ediyorsunuz. Onu da yine stil özelliklerinden açıp kapatabilirsiniz.
Buraya gidin
AdminCP > Appearance > Styles > Shadow - Style properties > ↓├ XenTR ┤ Breadcrumb || Disable top breadcrumb seçeneği etkin ise onu pasif hale getirip kaydedin.
Hepsi bu kadar. ;)
Cok tesekkurler Osman bey . Dedigizi yapinca duzeldi . Birde bu logo png mobile de cok kucuk gorunuyorr onun ayari varmi . Pc de sirun yok tesekkurler
XenForo'nun standart yapısı ne yazık ki böyle. Geçici bir çözüm olarak aşağıdaki kodu alt stilde yer alan extra.less şablonuna ekleyebilirsiniz.
CSS:
Bu akşam bu konuda bir güncelleme yapılacak. Dilerseniz onu yükleyin. Ayrıca gelecekteki düzenlemeler için de şablonlarda çok fazla oynama yapılmaması için yeni sürüme küçük bir eklenti dahil edildi. ;)
