Styles Ryzer Pro 2.2.8
Ryzer Pro
It has exciting features and excellent code quality.It has been designed and developed after thorough research to cater the requirements of people who interested in building user based directories. The design is contemporary but at the same time it focuses on the usability, visual hierarchy and aesthetics to ensure easy navigation for the end users.
37.50 $
65.00 $
48.75 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements Sürümler (24) İncelemeler (1)
A new update is available for Ryzer Pro by XenTR.
Ryzer Pro 2.2.8
This brings our styles up-to date with XenForo 2.2.8.
Please follow the update change log. You may download the update with a valid license.
Before Upgrading
XenForo 2.2.8 Compatibility Update
  • All outdated templates are updated to 2.2.8 and also confirmed XF v2.2.8 compatibility.
  • Template modifications are updated.
When uploading multiple images while posting in the section, clicking the Insert multiple, Select all button after the upload is complete is not valid.
Style Version: 2.2.8
Please check the issue, thanks.
HenJi ;
感谢您的反馈意见。 这些问题通常是由带有 .json 文件的插件引起的。
您可以尝试禁用您正在使用的插件吗?
Such problems are usually caused by javascript. Could you please check by disabling the add-ons you are using?
We will check whether the problem is caused by the theme and offer a solution.
Regards.
Hi HenJi we have detected the problem.
It comes from the button effect!
Could you please disable the button effect following style properties,
Also, we will release a new version as soon as possible!
Thank you for your feedback.
Hi Paras
Yes, we've checked it! We are working for new release.
To be clear, it's a loophole caused by the node icons, many actions are on our to do list that will improve the situation in the responsive (mobile) view.
We care about all feedback from our customers.(y)
  1. Ryzer pro
  2. ryzer
  3. icons
XenForo 2.1.x + XenForo 2.2.x XenForo 2.3.x
37.50 $
65.00 $
48.75 $
