Styles Ryzer Pro 1.0.9
Ryzer Pro
It has exciting features and excellent code quality.It has been designed and developed after thorough research to cater the requirements of people who interested in building user based directories. The design is contemporary but at the same time it focuses on the usability, visual hierarchy and aesthetics to ensure easy navigation for the end users.
37.50 $
65.00 $
48.75 $
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi System Requirements Sürümler (24) İncelemeler (1)
Ryzer Pro için XenTR kullanıcısı yeni bir güncelleme yayınladı.
Ryzer Pro 1.0.9
  • XenForo v2.2.3 Patch 1 compatibility
  • All templates are now compatible with XenForo's v2.2.3 Patch 1 Release.
  • The add-on for the theme has been updated. New add-on version 1.0.6
  • The scrolling problems in page loading in the new tickets area have been fixed.
  • Some issues reported by customers have been fixed.
XenForo 2.1.x + XenForo 2.2.x XenForo 2.3.x
37.50 $
65.00 $
48.75 $
