Styles Ryzer Pro 1.0.8
Ryzer Pro
It has exciting features and excellent code quality.It has been designed and developed after thorough research to cater the requirements of people who interested in building user based directories. The design is contemporary but at the same time it focuses on the usability, visual hierarchy and aesthetics to ensure easy navigation for the end users.
Genel Bakış Ürün Özellikleri Telif Hakkı Bilgisi Sürümler (12) İncelemeler (1)
Licenced Member
Web Sitesi
xentr.net
Ryzer Pro için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Ryzer Pro 1.0.8
  • XenForo 2.2.2 compatibility
  • All templates are now compatible with XenForo's 2.2.2 Release.
XenForo 2.1.x + XenForo 2.2.x
65.00 $
