Ryzer Pro için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Ryzer Pro 1.0.5
Note: This is beta software style. As you know, XenForo v2.2.0 Release Candidate 2 version is not officially supported.
We do not recommend running beta software in a production environment, and support is limited at this time to questions here on the community forums.
You must test your add-ons thoroughly or look for updates.
In this release, We updated style properties add-on for the footer statistics, also, you can find a new style property for forum title block under the page set-up properties. This property allows you to wrap up title section like as block.
Ryzer Pro 1.0.5
