Styles Nerva Light 2.2.3
Nerva Light
It’s a clean and simple theme that fully supports the latest XenForo community software. It will look great on any desktop, laptop, tablet or smartphone. Nerva light theme will help you to build a popular community.
10.00 $
Genel Bakış Telif Hakkı Bilgisi System Requirements Sürümler (24)
Nerva Light için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Nerva Light 2.2.3
  • XenForo v2.2.3 Patch 1 compatibility
  • All templates are now compatible with XenForo's v2.2.3 Patch 1 Release.
  • Some changes have been made to the xenmake.less file.
  1. xenmake xentr style
10.00 $
