Nerva Light için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Nerva Light 2.2.2
Nerva Light 2.2.2
- XenForo 2.2.2 compatibility
- All templates are now compatible with XenForo's 2.2.2 Release.
- A new style feature has been added for text logo usage.
- Some changes have been made to the xenmake.less file.
