Styles Nerva Light 2.2.1
Nerva Light
It’s a clean and simple theme that fully supports the latest XenForo community software. It will look great on any desktop, laptop, tablet or smartphone. Nerva light theme will help you to build a popular community.
10.00 $
Genel Bakış Telif Hakkı Bilgisi Sürümler (19)
Nerva Light için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Nerva Light 2.2.1
  • XenForo 2.2.1 compatibility
  • All templates are now compatible with XenForo's 2.2.1 Release.
  • Style now supports loading from archive.
10.00 $
