Styles Light Pearl v2.2.3 Patch 1
Light Pearl
Light Pearl Style comes with extended powerful, user full and flexible theme options that allow you to customize everything you can upload to your website in minutes.
Genel Bakış Telif Hakkı Bilgisi Sürümler (19)
Light Pearl için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
  • The PAGE CONTAINER template has been edited for the user fields.
  • Some macro structures were used in order to ensure that the user areas are compatible with other extensions.
  • The xm_visitorTabs template has been removed.
  • Some .less templates have been updated.
