Styles Light Pearl 2.2.7 Patch 1
Light Pearl
Light Pearl Style comes with extended powerful, user full and flexible theme options that allow you to customize everything you can upload to your website in minutes.
Genel Bakış Telif Hakkı Bilgisi System Requirements Sürümler (25)
Light Pearl için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Please do not install the style , if you are using lower than XF 2.2.x
Note: We strongly recommend installing the 2.2.7 Patch 1 Versions from the archive.
Updates after version 2.2.6.0.0 come with PHP 8 support.
  • Upgraded to xenForo 2.2.7 Patch 1
  • All templates are now compatible with XenForo's v2.2.7 Patch 1 Release.
