Styles Light Pearl 2.2.2
Light Pearl
Light Pearl Style comes with extended powerful, user full and flexible theme options that allow you to customize everything you can upload to your website in minutes.
Genel Bakış Sürümler (16)
Web Sitesi
xentr.net
Light Pearl için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Light Pearl 2.2.2
  • XenForo 2.2.2 compatibility
  • All templates are now compatible with XenForo's 2.2.2 Release.
