- Telefon No
- 053********
A new update is available for Light Pearl by XenTR.
Light Pearl 2.2.1
Light Pearl 2.2.1
- XenForo 2.2.1 compatibility
- All templates are now compatible with XenForo's 2.2.1 Release.
- Style now supports loading from archive.
- The add-on developed for the theme has been updated.
