Styles Innovate Light 2.1.5.1
Innovate Light
Innovate Light is a professional, flexible, fully-responsive forum theme for XenForo with a design and retina-ready graphics that is compatible with the most popular XenForo extensions.
10.00 $
Genel Bakış Telif Hakkı Bilgisi System Requirements Sürümler (24)
Innovate Light için XenTR kullanıcısı yeni bir güncelleme yayınladı.
This version is a quick maintenance update to fix some reported bugs.
Note: Update the add-on first. You can then update the style .
  • The add-on that comes with the theme has been updated.
  • Unable to view social connection icons problem solved.
  • PAGE_CONTAINER template updated.
  • Unnecessary templates were removed after the PAGE_CONTAINER template update.
  • The divider errors in the footer area have been fixed.
10.00 $
