Styles Innovate Dark 2.2.2
Innovate Dark
Innovate dark – premium XenForo 2.1.x theme with perfect responsive design and a lot of customization options available without any coding knowledge. Change overall layout just with few clicks!
Genel Bakış Sürümler (16)
Web Sitesi
xentr.net
Innovate Dark için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Innovate Dark 2.2.2
  • XenForo 2.2.2 compatibility
  • All templates are now compatible with XenForo's 2.2.2 Release.
  • A new style feature has been added for text logo usage.
  • Some changes have been made to the xenmake.less file.
XenForo 2.1.x
10.00 $
