Exclusive Light için @XenTR kullanıcısı yeni bir güncelleme yayınladı.
Exclusive Light 2.2.5
This version has resolved a problem detected in the macro structure of the navigation system. In this way, the problem for third party add-ons has been removed.
- XenForo v2.2.5 compatibility
- All templates are now compatible with XenForo's v2.2.5 Release.
- PAGE_CONTAINER and post_macros templates updated
